HT408 Offline
#1 Posted : Wednesday, 5 May 2010 4:41:01 AM(UTC)
HT408
LJ Torana 2 door rolling shell set up for V8
Shell was acid dipped and painted 4 years ago
Dead straight and 99% rust free, it would be hard to find a better shell!
Genuine GTR fluted front clip
LC GTR grille, headlight surrounds and tail lights
LJ GTR Seats with herringbone inserts and doortrims with GTR badges
LJ GTR dash and steering wheel
Leak free sun roof, centre mounted aerial and rear windscreen louvre
9 inch diff shortened 3 inches from standard
Moser billet axles with long ARP 1/2 inch studs
4.11 geared LSD centre
HZ drum brakes
Castlemaine Rod Shop chassis kit
Castlemaine Rod Shop front end strengthening kit
Steering modified to suit V8 with 2 x LH uni joints
HX front discs and alloy calipers
GTR XU-1 Bathurst twin diaphragm brake booster
Lowered King springs
Koni adjustable shocks
Nolathane bushes throughout
Widened and chromed HQ GTS rims 14" x 8" rear, standard 14" x 6" front with GTS centre caps
Twin 2.5 inch exhaust with crossover pipe and high flow mufflers
Autometer gauges and Nasco locking fuel cap pictured not included
The torana was previously fitted with a 308, trimatic and 9 inch. I have added the CRS chassis kit, billet axled 9 inch and exhaust. Plans have changed so it I am now offering it for sale. Everything has been done to this car to have it pass an engineer's report with no problems so just add your motor and box, then get an engineer's report and rego.
I can also supply the following parts at extra cost which are not included in the sale:
Castlemaine Rod Shop extractors high temp coated to suit Holden V8
Engine mounts to suit Holden V8
Holden V8 high volume oil pan and pick up
Gearbox crossmember to suit Turbo 350
3 inch thick wall tailshaft to suit Turbo 350 to 9 inch diff
6 point alloy roll cage
I'm after $12,000 for the Torana
I have tried to describe the car as best and honestly as I can. There are probably some things I have missed, there is really too much to list. The car is located at Dee Why, northern beaches, Sydney. You can contact me by calling Alex on 0404 113 734 or e-mail [email protected]
I will try to help out as much as possible with transport for the car but you'd best best off organising a car trailer or tilt tray for pick up.
Thanks,
Alex
Edited by user Wednesday, 18 August 2010 9:29:43 PM(UTC)  | Reason: Not specified
HT408 Offline
#2 Posted : Wednesday, 5 May 2010 4:41:57 AM(UTC)
HT408
HT408 Offline
#3 Posted : Wednesday, 5 May 2010 4:43:40 AM(UTC)
HT408
HT408 Offline
#4 Posted : Sunday, 9 May 2010 6:20:16 AM(UTC)
HT408
Some interest shown but nothing concrete yet.
HT408 Offline
#5 Posted : Wednesday, 18 August 2010 9:27:08 PM(UTC)
HT408
This was sold months ago.
Thanks.
