jayHK69 Offline
#1 Posted : Wednesday, 26 May 2010 9:23:20 PM(UTC)
jayHK69
will a B2 convertor be sufficent to run a impco 425 on a 350 chev ?
jayson
BIGCAV Offline
#2 Posted : Wednesday, 26 May 2010 9:38:05 PM(UTC)
BIGCAV
yes it will be ok.
personally if u want a better convertor go an impco model e.
i run a straight gas 425 with model L impco on my 351 cleveland.
made about 135rwkw threw an auto before it starts to die off but its the single mixer thats teh problem.
a 425 is only rated to 450cfm, the model e and l's are rated to 325hp from memory and the b2 is about 300
but the model e is just a nicer convertor and will run better
jayHK69 Offline
#3 Posted : Thursday, 27 May 2010 8:49:18 PM(UTC)
jayHK69
thanks mate.
just curious why the model e is the better convertor if the l has the same hp rating ?
my 350 is about 300hp.
thanks again
jayson
BIGCAV Offline
#4 Posted : Thursday, 27 May 2010 9:45:56 PM(UTC)
BIGCAV
the model e has a better water inlet/outlet design and some people say they can make that tad more power too, but officially there rated the same just a different design to each other
iv got a model L because i had one laying around, if i was buying new id go E but it doesnt bother me that much
with about 300hp u probably will notice a drop off in revs
i actually picked up down low power, but lost rev's purely due to the lower CFM rating of the mixer.
so youll probably find normal driving u wont notice a difference but on a dyno you wont pull the same power due to the loss of rpm (rpm = hp) etc
jayHK69 Offline
#5 Posted : Friday, 28 May 2010 4:59:15 AM(UTC)
jayHK69
that`s for the info greatly appreciated.
do you know if the OHG X1 is any good with the 425 or should i just stick with impco ?
BIGCAV Offline
#6 Posted : Friday, 28 May 2010 5:20:26 AM(UTC)
BIGCAV
the ohg x1 is bassically a b2 from memory, thats what lg coppied to make the b2
