MatildaHQ Offline
#1 Posted : Sunday, 30 May 2010 7:26:23 AM(UTC)
MatildaHQ
What would be the best way to strip back then refinish a set of wheels for my HQ? The set I have currently have a rubbish finish and need a bit of work.
Thanks, Steve.
#2 Posted : Sunday, 30 May 2010 7:39:41 AM(UTC)
A good gritblast and they'll come up like new ones. A coat of etch primer and then 2 hours with the masking tape.
I've had a few sets blasted and its about $30 a wheel I think.
59 Cadillac Coupe - 74 HQ GTS4 308 Cyan Blue - 74 HQ GTS4 350 Barbados Green - Nissan 350Z
MatildaHQ Offline
#3 Posted : Sunday, 30 May 2010 7:49:43 AM(UTC)
MatildaHQ
I thought that might be the case. We've just recently got ourselves a blasting box, just needs a trip to the hardware store to get her running. Guess I'll give it a whirl once she's goin.
Might be back to ask about paints in a few days.
Steve.
#4 Posted : Sunday, 30 May 2010 9:20:21 AM(UTC)
I would not grit blast mag wheels. Maybe walnut or plastic bead, or send them to a professional.
#5 Posted : Sunday, 30 May 2010 7:36:29 PM(UTC)
i had my rims sandblasted, they came up great, made painting so much easier
#6 Posted : Sunday, 30 May 2010 8:41:52 PM(UTC)
grit or soda blasting ,acid dip?
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
#7 Posted : Sunday, 30 May 2010 9:45:14 PM(UTC)
But these are not 'mags', these are pressed steel wheels. I've had heaps of these sand blasted.
I accept your point with any alloy wheels though.
The best argument against democracy is a 5 minute conversation with the average voter.
#8 Posted : Monday, 31 May 2010 3:10:20 AM(UTC)
You may like to consider having them galvanised as they are acid dipped prior to being dipped in gal, both of which provide the best protection against future rust forming between the center & the rim, plus there is no rush to get them painted & cost is generally a bit cheaper than blasting/dipping, my local gal plant charges around the $15 per rim.
HQforme Offline
#9 Posted : Monday, 31 May 2010 3:20:48 AM(UTC)
HQforme
Steel can be sandblasted. I blasted my wide steelies, then had them zinc plated and powdercoated. Great finish and well protected. Cost about $50 each rim.
"Silly modern cars"
"Silly modern cars"
MatildaHQ Offline
#10 Posted : Friday, 4 June 2010 2:34:54 AM(UTC)
MatildaHQ
Is it an easy task to separate the centre from the rim or should I simply blast them in one piece?
Also, of the four wheels, I have two different types of rims. One is a flat rim on the very outter edge, the other three are more rounded on the very outter edge. Any info on which is original?
Steve.
MatildaHQ Offline
#11 Posted : Friday, 4 June 2010 4:28:05 AM(UTC)
MatildaHQ
scratch the part about seperating the rim and centre, not worth the effort for the tiny bit more ease of stripping.
Steve.
