80737k Offline
#1 Posted : Sunday, 25 December 2005 5:42:45 AM(UTC)
80737k
g'day peoples, i have been busy replacing my XW sedan rear springs(S/H from wreckers).I used new eye and shackle bushes and i put in a set of new lowering blocks and finally added a set of 8"x14" mags with new 265/50 yokohamas, very pleased with it all until i realised the whole assembly sits to the left one inch more than it does the right. I've loosened everything and redone it all but still, 1" to the left. one thing i do note is the right wheel sits about 1" closer to the ground when the car's jacked up by the towbar, any ideas?
the only way i can see this problem arising is a broken spring but they look okay.
can anyone suggest what may be going on here? thanks and MERRY CHRISTMAS to the lot of ya's
Ooroo
Fossil fuels are YUMMY !
#2 Posted : Sunday, 25 December 2005 10:55:38 AM(UTC)
Have you got the spring on the righ way and on the right side if yes are the spring packs square if yes check the mounting blocks are the distance on both sides.
80737k Offline
#3 Posted : Monday, 26 December 2005 5:38:04 AM(UTC)
80737k
Merry xmas badfox (and the rest of ya's). Today i pulled my diff out then springs, put it all back in (the same as i did anytime before), Yippee, it's now sitting right, thanks for replying.
Ooroo
