Bluez Offline
#1 Posted : Tuesday, 15 June 2010 4:33:56 AM(UTC)
Bluez
Have an issue with the clutch pedal sometimes sticking to the floor too long and eventually springs back up.
Could more bleeding of the slave cyl or master cylinder be the problem or adjustment refining at the pedal and the slave? or maybe both?
regards
Paul
Jesse Jesse Jesse, you've not got a sense of humour!
petaus Offline
#2 Posted : Tuesday, 15 June 2010 5:27:29 AM(UTC)
petaus
when the pedal is stuck on the floor, is the clutch slave still pushing the clutch?
pete.
Bluez Offline
#3 Posted : Tuesday, 15 June 2010 5:57:51 AM(UTC)
Bluez
gday Pete,
The car is free wheeling at that point when the pedal is to the floor, and unusually when the car is turned off it doesnt stick, yet when the engine is spinning the flywheel it seems to happen as you rev the car more.
thanks
Paul
petaus Offline
#4 Posted : Wednesday, 16 June 2010 4:18:28 AM(UTC)
petaus
hi paul it not an old centrifgal style clucth is it? those things the harder you rev em the more the fingers move back pressing the throw out bearring back when it times to change gear you had to pump the pdeal abit befor the actual gear change?
Bluez Offline
#5 Posted : Wednesday, 16 June 2010 8:40:36 AM(UTC)
Bluez
gday Pete
No not a centrifigal clutch, its a 10.5 inch clutch behind sb chev to saginaw.
Paul
