#1 Posted : Sunday, 1 January 2006 2:13:39 AM(UTC)
electric tailgate window will fully wind up with the key from the rear but stops half way when u use the switch from the front which means if u r in the car when u reallize the window is not fully up u have 2 turn of the car remove key and walk around the back to rectify the problem any ideas why
#2 Posted : Monday, 2 January 2006 8:43:11 AM(UTC)
My guess would be voltage drop. I think the local switch is in parallel with the one on the dash, so a bad joint somewhere between the switch and the rear may be your problem.
