asdf88 Offline
#1 Posted : Sunday, 4 July 2010 11:15:24 PM(UTC)
asdf88
Hi all,
I have a HZ prem that needs a complete overhaul. It is a fully optioned one with aircon, power steer, auto etc.
The factory 253 is not running at all so I need to consider the options of engine replacement. I want to keep the Premier options of airconditioning and PS, but I want a manual gearbox conversion. Does anyone have a recommendation for the driveline? The options that I can think of are:
1. Get a reco 308 and muncie (or aussie). (I'm not keen on this one as I think that if I'm going to all the trouble of changing the engine I might as well get fuel injection).
2. Same as above but with aftermarket fuel injection. (I'm not sure about the ADR's on this one. Will the injection system pass the emissions requirements)?
3. VN 304 and T5. (I like this idea).
4. Gen III. (I don't know if an LS style engine will fit in the bay and not hit the airconditioning ducting. Also, as 5.7L engine was not standard, will this option need any engineering or approval inspections)?
Thanks and if you have alternative suggetions, please feel free to add to the list.
#2 Posted : Sunday, 4 July 2010 11:25:40 PM(UTC)
I'd just bolt a 308 and M20 or M21 aussie box in.
VN-VP 5.0L and TH700/4L60 is an easy upgrade. T5 is a little harder but still easy and will allow you to keep it standard ie no TH firewall hole for the speedo cable. Aircon is an issue with EFI.
#3 Posted : Sunday, 4 July 2010 11:30:10 PM(UTC)
1.Best and cheapest,easiest.
2.Expensive,harder to do,oh and did I mention,EXPENSIVE!
3.Probably the way to go,A little harder than..1,but benifits are huge
medium price for what you get.
4.Only do this if you have robbed a bank and abducted an engineer!
just my thoughts.!..P.S...there is a thread on here about all
of those choices,worth a read.
P.S....350 CHEV?..(engineer report required)
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
Edited by user Sunday, 4 July 2010 11:31:55 PM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 4 July 2010 11:43:48 PM(UTC)
if i was doing this sort of thing, i would definitely go the LS1 route.
first and most importantly, they are plentiful in EVERY form being from stuffed to new in crate. i will do point form actually
cheap engine if you but used one with no coils, $600 for that, or $1500 for a s/h runner here in melb
bits are easy to come by
you can run injection if you want,
you can run carb if you want GM make an intake to suit removal of injection and go NA
pacemaker make pipes for this swap
MSD make a box to run it
canton or moroso make a pan to suit the swap
plates for engine mount can be bought from CAE or easy to make your own, dont touch CRS bits
there are heaps and heaps of places making good hot up bits for them now
they make 600hp easy
being all alloy, they are LIGHT, infact, just a bit heavier than a holden 6 when you bolt on the accesories to them
you can still run all your P/S A/C and whatever else you like one the engine
you can bolt up T/400 or T/350 to it or late model 4 spd auto if you want to go that way
BAD STUFF.
you gotta be commited to finish the job as its still major work and you must have some mechanical apptitude to do any swap or else you might as well pay someone
dealing with places like CAE or CRS if you want to leave injection or find someone else to help with re programming and disabling what you dont need
T56 manual or whatever box it is wont fit unless you massacre the floor and tunnel of the car
they still dont sound like a ball tearing V8, no matter what you do to them(thats a good thing now as i'm gettin to old and cranky anyways for noise and i like a low profile now when driving)
not sure what state you are in, but reg can be gotten here in vic quite easily
if you want to go EFI Holden, buy a donor VN as hainzy is doing in his VH thread, but its still old junk that is getting harder and harder all the time and will still need the same sort of work to be done in regards to fiting it up, it just bolts in easier thats all
anyways, up to you, have a fistfull ready and go for you life son.
i have a good mate doing this LS-1 CARBIED swap into a LX torana as we speak, it looks the part, fits nicely and will be good for driving everyday, I'll get some pics up when i take some
Edited by user Sunday, 4 July 2010 11:47:50 PM(UTC)  | Reason: Not specified
52abel Offline
#5 Posted : Monday, 5 July 2010 7:15:37 AM(UTC)
52abel
Hi
I am do just what you are planning. I have put a 5 litre fro a VR into my HZ. I have removed the EFI (Thats me being old school) put in a crow Group A cam and a holly 600. It fits like a glove and parts are plebtiful. I have put an Aussie M21 four speed behind it and it fits right in ...no need to butcher the tunnel.. Gear stick comes right out of the same place as did the old trimatic shifter... tail shadts fits are well onlt other thing to do was to put in a holly blue fiel pump with a regulator and an MSD dizzy... very easy and cheap...goes well
have fun hope this helps
Originally posted by asdf88
Hi all,
hainzy Offline
#6 Posted : Monday, 5 July 2010 7:15:47 AM(UTC)
hainzy
WE wreck has given a great answer there if you wanna go down that path.
if you wanna do the 304 t5 combo have a look at my VH EFI thread below or above or wherever it currently is.. I know youre talkin a HZ and Im talkin VH but the wealth of knowledge across all models and helpful gurus that are on this site is amazing so whatever you decide theres plenty of info available.
asdf88 Offline
#7 Posted : Monday, 5 July 2010 9:41:09 PM(UTC)
asdf88
Thank you to everone's constructive comments. There are certainly alot of options and I guess it comes down to how much money is available to be spent.
I would like to have gone down the path of We Wreck's suggestion of LS1 to have the biggest and best, but I think that it will end up too expensive. For example, the LS1 will have to be engineered; I will probably need a new diff and tailshaft as the V8 Salisbury probably wont like the power.
With all the info so far on Hainzy's VH EFI thread, I will be following that one closely. I'm now leaning towards a 304 and auto as these seem to be much more plentiful (and cheaper).
In regards to the mounts from CRS, I have used a CRS crossmember in my Monaro and it fitted perfectly. I guess I must have got them on a good day?
Thanks again. Alan.
Mike81973 Offline
#8 Posted : Tuesday, 6 July 2010 10:37:50 AM(UTC)
Mike81973
Hi,
I fitted a 308 and VN heads to my HJ Statesman it is on straight gas so no problems with computers or ADR's and goes great.
I had to machine out clearance in the air con bracket for the PCV spout, I converted to a SD 508 Sanden compressor to fit the standard air con bracket by moved it forward, improving alternator access and steering allignment adjustment access and also moved the power steering forward and change the pulley to suit, but everything fits fine and I have driven it all over Australia with no dramas.
Had problems with the starter motor clearance as I used the red block, the VN block and starter would have worked out better.
Also had problems with fitting extractors as all companies I tried at the time claimed they had a product that fitted when in fact none did, it is easier now as at least one company does make a set that fits without burning your car. sorry don't know the name.
You could either use the VN injection or go straight gas, but I don't know why anyone bothers with petrol when gas gives more power and is cheaper.
I kept the Turbo 400 gearbox but as you wanted a manual, a all aussie would work if driven in a non agressive manner and would bolt in with a minimum of fuss, but obviously the later Borg Warner units would be stronger, but would require more money and modification to fit too.
I later steped up the diff ratio to use the increased power more efficienty too.
hope this helps,
Mike
Purpul Police
Edited by user Tuesday, 6 July 2010 10:53:03 AM(UTC)  | Reason: Not specified
Purpul Police
#9 Posted : Tuesday, 6 July 2010 5:41:54 PM(UTC)
The blocks did not change in the starter motor bolt-up area. The change was made to the converter cover. This change was made at the introduction of the VB in 1977.
A VN-VTI 304 starter motor will bolt up & work on an HT 253/308 if you leave the converter (or clutch) cover off. The hole in the converter cover can be enlarged to make it fit.
nzstato Offline
#10 Posted : Tuesday, 6 July 2010 6:42:27 PM(UTC)
nzstato
The good doctor is right. I made a 304 starter fit by hacksawing the 308 convertor cover around the back of where the starter would sit. That way you can bolt up the starter then bolt the cover in. Think what you are talking about is the orientation of the starter solenoid around the motor unit preventing extractors to bolt up. I know for a fact the aftermarket bosch unit will not fit with the genie headers I am running, the Holden unit will. If anyone want them I have some pics.
I have heard of some people using pontiac? starters on their holdens (supposidly gruntier/smaller)
asdf88 Offline
#11 Posted : Thursday, 8 July 2010 9:41:06 PM(UTC)
asdf88
I decided to buy a VS Commodore 5.0L Auto engine, transmission, loom and PCM from a wrecked VS Statesman. The numbers from the car were:
Eng. LB9
Trans. M30
Axle. GU4
Is the transmission a TH700R or 4L60E? Or are they both the same thing? Does anyone know what diff ratio the GU4 is?
I can see I will have a problem with the speedo. Is there a different extension housing available for this transmission that will accept a cable or will I need the electronic instruments out of the donor vehicle?
Thanks, Alan.
#12 Posted : Thursday, 8 July 2010 10:42:09 PM(UTC)
OK.
LB9 = 5.0 (304) EFI V8
M30 = 4L60-E auto
GU4 = 3.08 (or 3.07 for late VSIII V8) rear axle ratio
The best fix for the speedo is to buy an electronic conversion speedo for your HZ & stay with the electronic sender, the ECU needs to see that sensor working. You will also need to get the immobiliser removed from the mem-cal.
To explain the TH700 /4L60 thing. The original 4-speed auto was called the TH700-R4 up to 1990. When the Hydramatic division of GM was swallowed up into GM-Powertrain (1990) it was renamed the 4L60. For VR it gained electronic control & was then called the 4L60-E. So all 4-speed autos from VR to VZ, including yours are 4L60-E autos.
#13 Posted : Thursday, 8 July 2010 11:50:36 PM(UTC)
A further example to what Dr Terry has said: the TH400 was still around in 1990 when the change happened, and it became the 3L80 (used behind 454 in HD GMC and Chev pickups). When it was made into a 4spd around 1992 from memory it became the 4L80E. There was never a 4spd hydraulic only version so there was never a 4L80, although you can make one yourself by using a full manual valve body but you have to shift manually!
asdf88 Offline
#14 Posted : Friday, 9 July 2010 4:24:16 AM(UTC)
asdf88
Dr Terry,
In another thread, you said a VN fuel tank could be reconfigured to suit HZ style vehicles (by relocating filler neck etc). You recommended using the 6cyl one as it is a bit smaller than the V8 one and wouldn't hang down as low.
I've been reading a workshop manual for VR/VS models and it says that the 6 cyl ones are fitted with a single in-tank high pressure pump. The V8 ones have a high volume, low pressure pump and an additional high pressure pump in the fuel line.
When fitting the VS 5.0 engine to a HZ, which tank would you recommend? Does the 6 cyl high pressure pump have adequate volume for the V8?
Regards, Alan.
#15 Posted : Friday, 9 July 2010 5:39:42 PM(UTC)
That 2 pump scenario only exists for VN (& some VL/VK), that's why we recommend using VP-VS tanks.
The single intank high pressure pump is more than enough for a V8.
I'm doing one of these conversions currently & we are using a VS 6-cyl sedan tank.
Guest (11)
