Holdenon Offline
#1 Posted : Monday, 6 September 2010 3:37:29 AM(UTC)
Holdenon
Hi all,
I am looking at getting a Mongoose security system an include keyless entry on the HQ - now it is nice and straight and the one colour again.
The sparky said he has had trouble with the after market solenoids used as the Hq mechanism are heavy (and often full of dirt and crap).
Does anyone have experience with good heavy duty aftermarket solenoid which might be better???
thanks
#2 Posted : Monday, 6 September 2010 4:46:11 AM(UTC)
iv'e got central locking as part of my alarm on my HQ
the solenoids were struggling to unlock the doors, so i pulled the door locks apart and gave them a good clean with degreaser, they were still a little stiff but better
so i opened a door latch up and found the spring inside was a little to strong, so i removed it and stretched it slightly and put it back together, the door locks jump up and down very easy now, and have so for the last 2 years and i am still using the solenoids that came with the kit
#3 Posted : Monday, 6 September 2010 6:48:01 AM(UTC)
Was thanked: 603 time(s) in 570 post(s)
Also maybe look at HZ/WB solenoids?
Rhys Offline
#4 Posted : Monday, 6 September 2010 7:34:13 PM(UTC)
Rhys
I'm with Byron there, use the WB solenoids. Providing the rubber boots on the solenoid actuating arms are in good condition and not letting water/dirt in, they'll last forever.
I got a set of WB Statesman front door solenoids with the rods etc and fitted them to my WB Van, works great and strong as an ox. If you can chop the plugs off the door wiring harnesses and also grab the rubber door jam boots from the same car it will make the job look perfect.
Take the doors off and use a 32mm hole saw for the door jam boots. Try and find a HQ with electric windows so you can find out exactly where the 32mm holes are in the door jams. You may have some dimples to use as a guide but not all 8.
Not sure what the unlock/lock outputs are on a Mongoose but I have found that most brands usually use negative outputs that you can feed into 2 x changeover relays to make it all work.
#5 Posted : Tuesday, 7 September 2010 3:47:59 PM(UTC)
I'M with dave ,all new stuff and free up the old working parts,not that the others bad,I just think new
solenoids now ,old ones are getting a bit too old.just a thought.
Holdenon Offline
#6 Posted : Wednesday, 8 September 2010 2:22:02 PM(UTC)
Holdenon
Thanks for the comments. Defintely helps. I have WB solenoid in storage, however wont be able to get to them for a few months. The locks have been pretty well cleaned and lubed some time ago. Let you know how I get on....
