greenhj Offline
#1 Posted : Thursday, 16 September 2010 10:23:24 PM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
-HQ/HZ Drivers front bare, good condition
-HQ/HZ drivers rear with internals, needs work
-HQ/HZ drivers front, internals, needs work
-HQ/HZ drivers rear, internals, needs work.
2 are HZ gts, 2 im not sure.
all doors are 50 bucks each.
-HZ GTS guards, 1 genuine, 1 aftermarket, genuine needs work,aftermarket never fitted to car.
$400 the pair, or $200 for genuine drivers, $250 aftermarket, by virtue of condition
-HJ/HZ painted bumpers, one blue, one brown, with rubbers.
$100 each
-Single 2 1/4 exhaust was fitted to HV8/t400 kingswood, no tailpipe, used for 5 minutes to pass noise test, it passed with a 480hp stroked holden but underwhelmed on performance, great for a mild donk
$100
-HQ/HZ 308 HE sump, basic version with windage tray, no pickup, used
$100-
-VN/VP V8 steel tubular headers, one header cracked (as usual)
$50-
-173 red engine, 90% complete, has flywheel and clutch, less a few bits, CD prefix (lc/lj torana i think)
$100
-3 speed manual gearbox, came out of EH.
$50
-2 of yokohama ES100 tyres, 225/50/15, like brand new.
SOLD
-autometer 5" sport comp black 120mph mechanical speedo
$100-
16" single thermofan and steel shroud, to suit hq-hz radiators, needs 4 holes drilled in the side brackets to fit to your radiator, i might be able to rustle up the adjustable capillary type top hose switch too
$100-
VP 304 EFI stuff, heads, bananas, rails, auto computer, loom (loom missing MAP and TPS plug, and 1 Injector plug)
NO THROTTLE BODY
All sensors except MAP and TPS.
used, unknown condition on heads etc
$400-
55a alternator with v belt pulley, came off my car because i upgraded to 80a, good condition, not even 10000k's.
$100-
Also, im looking to sell a HZ 308+0.040" block with COME stroker kit, being freshened with new rings and a hone as we speak, has ARP main/head studs, basically a complete and assembled short.
can confirm compression ratio etc using your heads, it had 10.8:1 with my 56cc vn heads on board.
open to offers around 4k at this stage, price up the parts+machining+assembly etc, you wont build it for what ill let it go for.
ONLY reason for sale, is i just priced a 4 bolt conversion, forged pistons etc and for the money i may as well build a whole new engine
No reasonable offers refused, I wont take offense to your offer, if you dont take offense at my refusal and ill decide whats reasonable.
Contact via PM or post in this thread, pics available on request.
Melbourne location, freight at your expense, palleting will incur extra cost over freight unless by prior arrangement.
use 3175 as a rough estimate for post, will deliver anything within 20k's of 3175 except engine.
Ill add/subtract from this thread as i find/sell more stuff.
Phill
11.38@117mph
will go quicker
11.34@121mph
went quicker and faster, just not quick enough.
now being rebuilt with many more fasts
Edited by user Tuesday, 21 September 2010 7:01:38 PM(UTC)  | Reason: Not specified
greenhj Offline
#2 Posted : Saturday, 18 September 2010 8:15:11 AM(UTC)
greenhj
make an offer on the stroker short, this is a bargain and if it dont sell its going back in the car to chase 10's.
In a well setup commodore/torana with 4k convertor and high 3/low 4 gears it will run 10's with current cam, i used nothing more than cleaned up standard valve heads, redline single plane (and "everyone" will tell you how crap they are) and a 750dp carb to run 121mph a month or so ago in a 1560kg car on 235 MT radials.
Or, just whack in a mild cam, your top end, and enjoy a grunty cruiser.
11.38@117mph
will go quicker
11.34@121mph
#3 Posted : Tuesday, 21 September 2010 4:05:07 AM(UTC)
Hi,Would you be interested in sending the tyres to .S.A Adelaide(I would pay if you can arrange it)...If its too much trouble I'll understand..
greenhj Offline
#4 Posted : Tuesday, 21 September 2010 7:00:51 PM(UTC)
greenhj
sorry Jim, Tyres are sold!
ive had trouble getting on here the last day or so.
will update thread now.
11.38@117mph
will go quicker
11.34@121mph
#5 Posted : Wednesday, 22 September 2010 1:31:01 AM(UTC)
same here.thanxz
stephenreed Offline
#6 Posted : Tuesday, 28 September 2010 3:28:52 AM(UTC)
stephenreed
Hey mate have you still got the sump, what brand is it and what comdition is it?, could you maybe email or send me some pics on the phone. Also postage cost to parafield ardens, SA 5107.
Cheers Mate
Stephen 0409243594
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#7 Posted : Tuesday, 28 September 2010 6:51:31 AM(UTC)
greenhj
its a high energy sump, for holdenv8 into hq/hz. it will take 6.5l of oil though i tend to fill 5.5 plus filter.
Its what theyd call their "basic" design, being that it has a decent windage tray but no gated baffles around the pickup.
I had it on an engine turning 7000rpm.
Ill try and grab some pics during the week, there is no pickup supplied though i used a standard one anyway on that engine/sump, just be sure to check pickup to base of pan clearance (blob of blutack or plasticene works well for this)
condition is decent (its only a sump lol) it aint been beaten to death to clear anything or used to skid over rocks.
about all thats "wrong" with it is its dirty and while id give the outside a wipe with a rag, the inside will need a decent degrease and high pressure clean and frankly, im too lazy to do that for something thats sitting on the shelf and unlikely to be used by me unless i attach it to the short motor ive got and sell the lot.
its black in colour...
11.38@117mph
will go quicker
11.34@121mph
Edited by user Tuesday, 28 September 2010 6:54:43 AM(UTC)  | Reason: Not specified
stephenreed Offline
#8 Posted : Wednesday, 29 September 2010 7:11:00 AM(UTC)
stephenreed
Cheers, I,m keen to grab it. Need to figure out postage costs first. Could I get weight and rough size and your postcode so I can work it out please.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
greenhj Offline
#9 Posted : Friday, 1 October 2010 7:29:59 AM(UTC)
greenhj
no worries, ill take some measurements and whatnot, FWIW i sent some 9" gears to queensland recently and postage for the (almost) 9kg box came in at 17 bucks so i doubt the sump will be much different to that price.
can i talk you into a rebuilt 355 short to attach to that sump too? lol.
11.38@117mph
will go quicker
11.34@121mph
Edited by user Friday, 1 October 2010 7:30:40 AM(UTC)  | Reason: Not specified
stephenreed Offline
#10 Posted : Friday, 1 October 2010 5:10:51 PM(UTC)
stephenreed
Its the size that will make the cost change in this situation. They have 2 cost scales one for size and one for weight but that shouldn't be a drama i can figure out basic measurements from a stock sump.
As for the 355, i'm just putting my 355 for my HQ tonner back together all forged, so i'll have to pass, lol.
**CHOPP3R**
71 HQ TONNER
01 WH STATESMAN
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
Guest (10)
