Goodo Offline
#1 Posted : Saturday, 25 September 2010 10:52:17 PM(UTC)
Goodo
On ebay there 2 lots of engine mounts the first one is 150496863404.
The second one is 200512866463. The second one has more parts, Do I need all of these parts or just get 2 brackets as they are cheaper. I dont want to buy the 2 brackets then find out I need all the other stuff as well and will work out dearer.I am putting 289 in xp falcon. Thanks goodo
Edited by user Saturday, 25 September 2010 10:53:06 PM(UTC)  | Reason: Not specified
www.earlyfalcons.com Offline
#2 Posted : Sunday, 3 October 2010 7:57:19 AM(UTC)
You will need a complete kit (the kit is mine listed on Ebay). Any engineer will make you fit an under sump brace. Also the other mount is for your C4 or manual gearbox to mount to begind the V8. The other listing is for the V8 mounts only and yes, will cost you more in the long run buying the other mounts seperately.
#3 Posted : Wednesday, 13 October 2010 7:21:04 AM(UTC)
Yes I'd get the whole kit. It was remiss of Ford in the first place not to put a cross member between the front suspension arms and would almost certainly cause undesirable handling traits on a V8 engined car without one.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
