Mint julip Offline
#1 Posted : Sunday, 31 October 2010 10:00:47 AM(UTC)
Mint julip
Anyone know what this engine number means decoded for this engine? JG34RU50472K
castellan Offline
#2 Posted : Sunday, 31 October 2010 9:28:10 PM(UTC)
castellan
Fairmont sedan oct 1975.
Mint julip Offline
#3 Posted : Sunday, 31 October 2010 10:19:44 PM(UTC)
Mint julip
Thanks for this info but I am trying to break down the numbers off it to work out if it is a 302c or 351c?
Paul351xb Offline
#4 Posted : Monday, 1 November 2010 4:37:44 AM(UTC)
Paul351xb
you cant do that with the engine numbers. only way to tell is either find the original vin tags or crack the motor open and look at the crank. the other way is to take out a spark plug, put a piece of wire down onto the top of the piston, hand turn the motor and measure the length of the stroke. I can't remember the measurements but I'm sure somewhere here does.
Support female jelly wrestling. We can stop men going to war and solve world hunger all at the same time.
BIGCAV Offline
#5 Posted : Monday, 1 November 2010 6:12:30 AM(UTC)
BIGCAV
3" for 302 and 3.5" for 351
Mint julip Offline
#6 Posted : Monday, 1 November 2010 7:44:07 AM(UTC)
Mint julip
Thanks guys, will check it out and let you know the results. Cheers.
Anthony P Offline
#7 Posted : Monday, 22 November 2010 9:12:35 PM(UTC)
Anthony P
The easier way is to call Ford and get an Old Vehicle Report because the engine number is the same as the VIN.The report will tell you the engine size.
