#1 Posted : Tuesday, 21 December 2010 4:54:42 AM(UTC)
A technical one..
My Kia has two solid state coils, each has a spark plug lead connected straight to it, with another lead off to the other plug.
The spark timing is controlled by a peg on the end of the exhaust camshaft that rotates around inside a sensor thingy.
My question is, the peg only approaches the sensor once in each 2 rotations, assuming the camshaft is running at half engine speed.
So how does the computer know when to fire the other 3 plugs??
just trying to catch up with the 20th century..
petaus Offline
#2 Posted : Tuesday, 21 December 2010 5:26:47 AM(UTC)
petaus
hi john, if you look further it will have a crank angle sensore, some where either on the balancer or the flywheel or in the block of the crankshaft, which i think the kia run the internal one.
some systems only use the cam sensor to start to work out the firing position of the crank then the computers remembers where it,s at vn v6 style commodore was like that once running did not need the sensor. other systems look at the cam sensor all the time.
a js vectra will start with the crank angle sensor disconected takes longer to start while it works out the crank /cam relationship then is rev limited till about 4500 rpm as it has no real speed siginal, new systems now can tell you which cylinder is miss firing from the crank angle/ cam angle sensor it see the crankshaft slowing down then speeding up again as the cylinder does not fire correctly the computer can log a code telling which cylinder.
with my tech 2 scan tool i can do a cylinder balance test it,s cuts out the injecter to each cylinder then records the average rpm drop so you can see if each cylinder is doing the same amount of work. pete.
This page was generated in 0.017 seconds.
