cheezel308 Offline
#1 Posted : Monday, 17 January 2011 7:15:37 PM(UTC)
cheezel308
anyone fitted em?....do i have to run new wiring/relay?
thanks in advance..Mick..
#2 Posted : Monday, 17 January 2011 8:08:29 PM(UTC)
Hella H4s will fit directly into an HG.
A relay will improve the lighting slightly, but you don't really need a it, the H4s draw less current than sealed beams.
Dr Terry.
cheezel308 Offline
#3 Posted : Monday, 17 January 2011 9:44:21 PM(UTC)
cheezel308
awesome...thanks doc!
#4 Posted : Tuesday, 18 January 2011 1:40:28 AM(UTC)
hq the same??
#5 Posted : Tuesday, 18 January 2011 3:17:05 AM(UTC)
Originally posted by jim
hq the same??
Yes, but you need to allow for the park lights if it's a 73/74 model.
Dr Terry.
#6 Posted : Tuesday, 18 January 2011 3:38:40 AM(UTC)
twin filament indicators?
#7 Posted : Tuesday, 18 January 2011 4:15:38 PM(UTC)
I fitted twin halogens to my van with no relay and if i leave the high beam on it burns out the light switch, any ideas or does it need a relay?
#8 Posted : Tuesday, 18 January 2011 5:30:31 PM(UTC)
Sounds like you need a relay to me. Too much current through the switch.
#9 Posted : Tuesday, 18 January 2011 6:10:42 PM(UTC)
It all boils down to current draw.
An original 7-inch sealed beam headlight unit is rated at 70/50, which means 70-watts on high beam & 50-watts on low beam. A normal H4 dual filament headlight globe is rated at 60/55 (60W hi & 55W lo), so the total power when on high beam in a H4 is 2 x 60-watts (120-watts) which is 10-amp current draw. Normal sealed beams are 2 x 70 = 150-watts or 12.5 amps current draw.
If you start fitting 100 or 130 watt halogen globes, say 4 of them, this totals a possible maximum of 520-watts, which is over 43 amps. A headlight switch, which in the case on early Holdens incorporates a thermal circuit breaker which would burn out big time under that sort of load.
This is where relays are required.
#10 Posted : Wednesday, 19 January 2011 5:19:33 AM(UTC)
kelvin01au Offline
#11 Posted : Wednesday, 19 January 2011 7:07:10 AM(UTC)
kelvin01au
i have had h4 lights in the ht for about 5 years with a narva headlight relay. driven from brissy around tassie and great ocean road. best thing i ever put in the car. i have just bought a set of hid h4 replacement that i will fit up soon.let you know how they work. kel
Jul71-Oct74 Offline
#12 Posted : Wednesday, 26 January 2011 7:42:01 PM(UTC)
Jul71-Oct74
Can anyone help with this one. My Hq with standard sealed beams is fine on normal beam but the lights will start to flicker and cut out if left on high beam for more than about 10 minutes. I get around it by not keeping high beam on for too long.
Thats fine, but if someone can tell me what the fix is that would be better.
Thanks for any advice
#13 Posted : Thursday, 27 January 2011 12:25:13 AM(UTC)
High current draw?..fit a relay .
Guest (5)
This page was generated in 0.164 seconds.
