#1 Posted : Thursday, 27 January 2011 12:25:44 AM(UTC)
Was thanked: 603 time(s) in 570 post(s)
Anyone know where to buy these nowadays? Used for many years in diff conversions. Basically they are a Fod 1/2" wheel stud, machined and threaded to a GM size stud except the threaded part is offset by 1/8" from the centre of the head. What it does is allows you to put the studs in Ford axles with a 4.5" PCD and have them one way giving you a 4.75" PCD or spin them 180 degrees to give you a 4.25" PCD. I've searched everywhere but can't find them.
Edited by user Thursday, 27 January 2011 8:06:31 PM(UTC)  | Reason: Not specified
Utility8 Offline
#2 Posted : Thursday, 27 January 2011 6:50:39 PM(UTC)
Utility8
Maybe I'm way off beam here, don't be afraid to tell me, I'm a grown man, (sometimes), but do you think there is a reason you can't find 'em?
Utility8
utility8
#3 Posted : Thursday, 27 January 2011 6:56:13 PM(UTC)
I thought that. They worked fine on the diff conversion I had in an L34 Torana, I just wondered if they were still around. Look like a very simple, safe and effective way to do a stud pattern conversion.
#4 Posted : Thursday, 27 January 2011 7:53:26 PM(UTC)
I haven't seen those since the early 80s, I don't think that they still make them.
I don't follow the logic on rotating them 180 degrees to give the 4.5-inch PCD. Shouldn't that be a 90 degree rotation to get 4.5-inch. If you rotate 180, the result would be 4.25-inch PCD.
Dr Terry.
#5 Posted : Thursday, 27 January 2011 8:07:12 PM(UTC)
Terry, 100% correct. I fixed the original post so it makes sense (I left the 2 out).
Utility8 Offline
#6 Posted : Thursday, 27 January 2011 10:11:14 PM(UTC)
Utility8
In all seriousness, I would be very surprised if they would come close to being an acceptable way to achieve a stud pattern change. Particularly these days where the requirements are getting more stringent. I would think the only application would be for static mounting of machinery or the like where the mounting holes are offset &/or of different thread requirements. Dynamic load, not to mention wheel centering, would be the problems with such a system. Even changing the stud pattern of a factory axle by plugging & redrilling is not a sound method.
Although a little dear, I had a set of Moser axles built to spec for a 9" for the car below about 10 years ago. Great way to achieve any stud pattern/brake/bearing combo you could ever want.
In real terms, good bang for buck.
Utility8
utility8
petaus Offline
#7 Posted : Friday, 28 January 2011 6:44:06 AM(UTC)
petaus
lol i remember my mates lh torana with nine inch conversion, ford axles drilled to lh then redrilled to hq they were like swiss cheese,lol i allways woundered if it was my last ride everytime i got in that car
