#1 Posted : Saturday, 18 February 2006 9:58:37 AM(UTC)
Hi, I am after a 9 inch LSD (3.5:1) to suit a HZ Tonner. Just the housing and center would be fine as I have axles (Holden disc brake and drum brake 10 bolt axles) and brakes but if it is complete, Holden stud pattern and brakes disc/drum is what I am chasing.I would prefer it to have WB rotors and callipers that have been set up correctly to clear the leaf springs and comes with the correct length and fitting park brake cable. I am in the Brisbane area, and for myself to arrange a courier may not be a problem in some areas. Cheers TD
PS.... Do the original Holden axles have to be modified in any way or are they the same spline as the 9inch side gears and will the lengths remain the same because the same Holden axle housing is welded onto the Ford center Housing. Cheers again TD
Please e-mail sharlees @ tpg dot com dot au
This page was generated in 0.103 seconds.
