Is there anything u can put on the label to make it come off easier . Usually u can just peel it off one corner and at the end u get all the adhesive which is also hard to get off . Eucalypt oil ?
Trust me...water and glad wrap ..leave it "soaking" for a while..then presto!..let us know how you go.
Jim in Adelaide.. |
Jim in Adelaide.. |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
wet the glad wrap and spread it on and leave it.
Jim in Adelaide.. |
Jim in Adelaide.. |
Fold up a piece of newspaper about 5 thick and dampen with water then press up against sticker for 5 mins
Mark
thanks fellas , still not easy but got it off with the glad wrap so thanks jim and windexed the left over adhesive .
get a bttle of 'goo remover' or 'desolve it' from Coles/Woolies etc to get the residue off then clean window as you normally do
Greetings, WD40 is the go. Works like magic. look out, the guru is coming through... |
