Will HQ-WB 1 tonner front stub axles raise your HQ-WB sedan by about 20mm?
Are there any other model stub axles that will fit, and also fit the HJ caliper? |
Thanks: 1 times Was thanked: 601 time(s) in 568 post(s)
No. Tonner are identical to others just heat treated.
There are 4 x different disc brake stubs for HK-WB:
HK-mid HX (HK-HG are opposite hand so swap sides) HQ-mid HX tonner late HX - WB late HX-WB tonner. |
