Woodsy Offline
#1 Posted : Tuesday, 22 February 2011 10:42:58 PM(UTC)
Woodsy
Needed Urgently Looking to borrow a fuel pump to suit a VS V6. I think some earlier models use the same pump. Need it for testing purposes and if its the problem we will buy a new pump.
Can pick up on the Central Coast, NSW
PM Me or Reply here.
Cheers Josh
Josh
obsessed Offline
#2 Posted : Wednesday, 23 February 2011 3:25:47 AM(UTC)
obsessed
If you cant hear the fuel pump working with the ignition on then that will definately be your problem
Woodsy Offline
#3 Posted : Wednesday, 23 February 2011 3:38:08 AM(UTC)
Woodsy
The pump only primes for 2 seconds with the ignition on then it turns off like it should, then with the car running the pump works but its meant to have a flow rate of 1.25 litres in 30 seconds, we are getting 750ml to 30 seconds, but we are not sure if its meant to be running or cranking with this test.
Edited by user Wednesday, 23 February 2011 3:39:44 AM(UTC)  | Reason: Not specified
Josh
Duzty Offline
#4 Posted : Thursday, 24 February 2011 4:23:34 AM(UTC)
Duzty
can sell you a brand new bosch one for $50
This page was generated in 0.104 seconds.
