Premier 350 Offline
#1 Posted : Monday, 14 March 2011 1:53:29 AM(UTC)
Premier 350
Well, I'm now the proud owner of a 10-84 built WB Deville.
No motor, front seats, door mirrors, or headlights. ( I reckon they're gracing a ute somewhere)
My question is. Is a 350 Chev legal in a WB? Esp with a Holley.
Reason for asking is that said 350 is available and ready to drop in.
TH 400 & X member there as well.
Or I rat the WB for the HQ- can any one confirm if the WB half chassis will work with HQ sheet metal? And from memory, arn't the WB
chassis side rails shorter than HQ?
satanic customs Offline
#2 Posted : Monday, 14 March 2011 3:03:32 AM(UTC)
satanic customs
go with the HQ.
all the missing bits are the costly to replace items due to their popularity with ute enthusiasts, particularly the headlights at approx 250-300 each.
i would put the wb diff in the hq though. 4 wheel discs are not a bad thing.
your premier isn't purple by any chance is it? i still have certain red wagon lying around that once had a 350 in it. sound like your old one?
#3 Posted : Monday, 14 March 2011 3:06:54 AM(UTC)
With straight LPG you can put a Chev into a WB. Bit hard on ULP. Being a 10/84 it'll be a trimatic too, not a TH400.
WB rails are basically a bolt into a HQ. Only difference is the nose of the rails are removed to clear the radiator support, so the HQ front bar bolts (1 per side) cannot be fitted - you have to use just 2 per side. In most Australian States the reulting car will be a WB though and will have to comply with the same emissions laws as the Statesman.
greenhj Offline
#4 Posted : Monday, 14 March 2011 3:20:42 AM(UTC)
greenhj
you wouldnt happen to have a pic of the WB rails, that show the "missing" bit?
Edited by user Monday, 14 March 2011 3:24:10 AM(UTC)  | Reason: Not specified
#5 Posted : Monday, 14 March 2011 4:05:16 AM(UTC)
No, but it just the nose. You know how they are rounded on HQ-HZ? WB has the front about 30mm or so cut off, and the frontmost bar bolts are moved backwards by about the same amount.
greenhj Offline
#6 Posted : Monday, 14 March 2011 4:35:22 AM(UTC)
greenhj
yep, thats pretty much what i figured, thanks!
Edited by user Monday, 14 March 2011 4:36:25 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#7 Posted : Monday, 14 March 2011 12:07:38 PM(UTC)
adam PERTH
you may have a tougher time with a later series 2 Wb stato and Holley than a normal HQ - WB as there are more ADR requirements on 10/1984.
also, you stato probably had a trimatic and the crossmember is different (but can be nodified) to suit T400
most late WB ststos i have seen have XV-9 ?? on the ID tag. not sure if this relates to emmissions controls. but on the 6 cyl Late 1984 WB's they had extra emmission controls than the early 202 blue.
Rhys Offline
#8 Posted : Monday, 14 March 2011 6:30:37 PM(UTC)
Rhys
Adam,
8WS19 = WB Deville
8WT19 - WB Caprice
8WS19-XV4 = WB Deville Series II
8WT19-XW9 - WB Caprice Series II
You're right the the 202, but I think it was just those that built for NSW, all other states didn't have the extra emmission controls.
adam PERTH Offline
#9 Posted : Tuesday, 15 March 2011 9:03:07 AM(UTC)
adam PERTH
cheers rhys..
OldDog Offline
#10 Posted : Sunday, 3 April 2011 6:44:29 PM(UTC)
OldDog
Premier, I'm currently building up one WB ute out of two, it has a 350 and TH350 box in it (this is in NSW) i can get full rego on this car as it has a straight gas setup. I need to get it engineered to get registration. Of the bits you're missing i have a set of WB mirrors plus other stuff if you need em let me know.
Premier 350 Offline
#11 Posted : Wednesday, 6 April 2011 9:03:58 PM(UTC)
Premier 350
Hi Old Dog,
PM sent.
Guest (6)
