cheezel308 Offline
#1 Posted : Sunday, 22 May 2011 12:33:30 AM(UTC)
cheezel308
Hi guys,anyone ever changed a reaction disk in a HK-HG brake booster??
i'm told it's not hard but i've never done it,
cheers Mick
#2 Posted : Monday, 23 May 2011 4:32:17 AM(UTC)
i had one in a HQ booster fall out when i was painting it, it was rattling around inside the booster, it was easy to get back into place, if there same as HQ it's as easy as pulling the master cylinder off and the rod and seal pulls out, and the disk is straight ahead
try using a stick with something like a sticky dot (that stuff that looks like snot) or a drop of glue on the end and poke it up the hole and the disk will stick to it and pull it out, do the same to get it in
as confusing as all that ^^ sounds it is acully quite easy
cheezel Offline
#3 Posted : Monday, 31 October 2011 5:50:57 AM(UTC)
cheezel
do you have to bleed the brakes after this?
cheezel308 Offline
#4 Posted : Monday, 28 November 2011 1:20:24 AM(UTC)
cheezel308
well and well?
petaus Offline
#5 Posted : Monday, 28 November 2011 2:16:56 AM(UTC)
petaus
no you should not have to bleed the brakes
#6 Posted : Monday, 28 November 2011 5:01:28 AM(UTC)
as above, no you don't
