#1 Posted : Tuesday, 25 May 2004 3:19:51 PM(UTC)
Hi.. Which model commodore has an electronic dizzy that could be swapped on to a red motor(179)? What parts are nesisary to transplant, and are any other modifications involved??
Any help greatly appreciated :)
#2 Posted : Wednesday, 26 May 2004 2:13:55 AM(UTC)
WB, VC, VH and VK EFI.
you need the dizzy, coil and leads, regap standard red motor plugs to 1.5mm (60thou i think) you need to replace the wire that runs to the coil so you get a full 12 volts, or use the exsiting wire to switch a relay which gets
#3 Posted : Thursday, 27 May 2004 2:32:57 AM(UTC)
Too easy. thanks Dylan.
