#1 Posted : Wednesday, 22 March 2006 7:42:11 AM(UTC)
Guys,
Prev owner ran straight water, topped up every two weeks, known to get hot.
I drained and flush radiator, replace thermostat with a "hi-Flo" unit that opens at 170 Fahrenheit, new thermostat gasket and put in high qual Coolant concentrate and added 50% water. Fitted new temp gauge and Sender unit, appearred to be ok.
I drove the car about 30-50kms yesterday, seemed to be sitting on 90deg nicely, I have the mech fan and shround with a backup manual Elect fan. This morning I checked Rad Fluid, and level hadn't budged.
Drove car another 20kms this morning, with elec fan off, testing the cooling system, heated up a bit, but around the 80-90 mark. Parked car and turned off when it was at 80deg.
Came back an hour later, turned car on (temp read 60, usually 0 if left overnight) and drove to work (15km) halfway there temp goes up to 120deg (offscale) get to work, few drops of coolant look like they came out overflow, no real signs of leaks, rad cap is making small sound.... later I top the radiator up to find i've lost 2.5L of fluid!!!
Im working night shift, so will fix tomorrow, any ideas? I'm gonna look at water pump, check for any leaks (any ideas on best way) and poss get pressure tested?
Any other suggestions would be great!
Thanks.
1976 HX Ute 308
Edited by user Wednesday, 22 March 2006 7:43:31 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 22 March 2006 9:09:00 AM(UTC)
i had troubles like yours. it ended being my radiator cap wasnt holding pressure.
#3 Posted : Wednesday, 22 March 2006 9:26:34 AM(UTC)
Thanks Mikey, I'll replace that first thing to see if it makes a difference.
Is there anyway of testing if a water pump is actually pumping? or if the Thermostat has opened? or any other test I should do while im at it?
I may take it to be pressure
#4 Posted : Wednesday, 22 March 2006 9:47:39 AM(UTC)
Could disconnect top radiator hose from radiator and start the engine it will show if the pump is working. Most likely it is the cap the symptoms are consistent with that.
lonemonaro Offline
#5 Posted : Wednesday, 22 March 2006 10:46:32 AM(UTC)
lonemonaro
Pressure test radiator for possible leaks at radiator cap or hoses.
Overheating can be caused by a corroded out water pump and may have been over compensated by use of electric fan.
Best to remove from vehicle and properly check it, as it may have
#6 Posted : Thursday, 23 March 2006 7:40:00 AM(UTC)
Thanks guys, ive replaced the radiator cap, and also managed to tighten the top hose clamp a bit more, noticed there may be a very small leak around the new gasket on the thermostat housing, ill tighten it up a bit more tomorrow...
Temp looked pretty g
JBM Offline
#7 Posted : Tuesday, 28 March 2006 9:30:50 PM(UTC)
JBM
If the water pump bearing seal is worn out water will piss out the hole underneath where the the fan and pulley bolts on.
Have your cooling system pressured tested, will tell you exctly where water is leaking from, may be Welsch plugs.
Straight wate
#8 Posted : Wednesday, 29 March 2006 11:51:32 PM(UTC)
A slow opening thermostat will give problems as well. What happens is that the thermostat does not open gradually as it is supposed to and ultimately goes from fully closed to fully open. This allows a surge of built up water pressure to hit the radiato
