bluHJ Offline
#1 Posted : Saturday, 16 July 2011 2:06:26 AM(UTC)
bluHJ
I'm heading across to the west again and have decided to upgrade the headlights in the VY. Although the lights are fairly good, I thought I might go for either 90/100 watt in the main part of the headlight or 100 watt in the spot light part.
Is there any problem with this upgrade due to the plastic lenses or wiring?
cheers...bluhj
#2 Posted : Saturday, 16 July 2011 2:15:33 AM(UTC)
Was thanked: 242 time(s) in 216 post(s)
The wiring & relays will be OK, but make sure you get globes which have 'low UV' otherwise the polycarbonate lenses will yellow. This is true for any replacement globes not just the hi-output ones.
bluHJ Offline
#3 Posted : Saturday, 16 July 2011 2:45:14 AM(UTC)
bluHJ
Thanks Terry but when you say low UV, is that something to do with the k rating? I had 100/130's in my J but it had glass lenses.
Rhys Offline
#4 Posted : Saturday, 16 July 2011 6:41:01 AM(UTC)
Rhys
bluHJ
I would also recommend keeping the outside of the lenses super clean so that they can more effectively dissipate the heat, they get bloody hot with high wattage globes in them!
69 rust bucket Offline
#5 Posted : Saturday, 16 July 2011 9:59:23 AM(UTC)
69 rust bucket
if you want good clear bright lighting go for a hid 35watt kit way brighter than a 90/100 watt halogen less heat better lighting but illegal in most states but so are 90/100 watt halogen
why drink & drive when you can drift & slide
peter_flane Offline
#6 Posted : Saturday, 16 July 2011 10:04:00 AM(UTC)
peter_flane
Just remember you need to make sure your lights are adjusted correctly. Why?
Well do you get annoyed with bright annoying lights coming towards you? Are you one of them?
bluHJ Offline
#7 Posted : Saturday, 16 July 2011 11:43:25 PM(UTC)
bluHJ
Thanks for all the suggestions but I saw my model with driving lights on a light bar and liked the look of them. Went and bought a set of 100 watters and a bar. I''ll be putting them on tomorrow.
69 rust bucket
What state are you in? I'm in Vic and there's nothing in the vehicle regulations here that say higher wattage lights are illegal. They just have to be the same output left and right.
cheers...bluhj
#8 Posted : Sunday, 17 July 2011 1:45:00 AM(UTC)
don't forget you must fit a relay and larger wires to the driving lights,and they must by law be wired so they only come on when on high beam.
pick up a wire from the high beam circuit or from the fuse if high beam has a separate fuse run it to power the relay then to the driving lights from the relay. if you try to wire the driving lights straight from the dipswitch the dipswitch will overheat and burn out. then you have to dismantle the steering column to get at the light switch lever bits.and buy a new light switch.
also there is a national code that regulates lighting and there is a limit on what you fit to the headlights, applies to all states. just ring you local traffic licencing people they will tell don't rely on hearsay you get off the net! we all know how reliable that can be.
see you over here.
bluHJ Offline
#9 Posted : Sunday, 17 July 2011 3:47:50 AM(UTC)
bluHJ
All done that way John but thanks for the info anyway. I have run a relay and fused that as well. They are fitted as required by the regulations into the high beam as in they only work when on high beam as well as an inline switch to stop them working if I want. I probably don't need them as last time I went, the standard ones were ok but I prefer to see a bit more, especially if I start early or run after dark like I did last time. I had no problems with wildlife and did do a bit of dusk and dawn driving as well. For your info if you are interested see the ADR copy and paste.
ADR13 specifies
7.3. DRIVING LAMPS
7.3.1. Presence: Optional on motor vehicles. Prohibited on trailers.
7.3.2. Number:
7.3.2.1. Two or four.
7.3.2.2. To be used in conjunction with headlamps.
7.3.3. Arrangement
No individual specifications
7.3.4. Position
7.3.4.1. In width no individual specifications.
7.3.4.2. In height: no individual specifications.
7.3.4.3. In length: at the front of the vehicle and fitted in such a way that the light emitted does not cause discomfort to the driver either directly or indirectly through the rear-view mirrors and/or other reflecting surfaces of the vehicle.
7.3.5. Geometric visibility
No individual specifications.
7.3.6. Orientation
Towards the front.
7.3.7. Electrical connections
The driving lamps must be able to be lighted only when the main-beam headlamps switch is in the �lamps on� position.
7.3.8. Tell tale: No requirement.
7.3.9. Others
The aggregate maximum intensity of the main-beam headlamps as specified in paragraph 6.1.9.1 of Appendix A can be exceeded with the fitment and illumination of driving lamps. Driving lamps do not have to comply with ADR 46/�.
And Appendix A
6.1.9.1. The aggregate maximum intensity of the main-beam headlamps which can be switched on simultaneously shall not exceed 225,000cd, which corresponds to a reference value of 75.
6.1.9.2. This maximum intensity shall be obtained by adding together the individual reference marks which are indicated on the several headlamps. The reference mark "10" shall be given to each of the headlamps marked "R" or "CR".
As my headlights are marked with an R and are standard globes, each of the high beam (4) equals 40, well under the 75 maximum. As you can see from 7.3.9, driving lights do not have to comply with ADR 46 which is the lighting requirements. However, both of them are also marked with an R so even if I have to add another (2) totaling another 20, I am still under the 75.
Even the police over here fit driving lights to their cars and have the same arrangement to what I now have. I have been a member of the Victoria Police Highway Patrol for over 29 years and am well aware that they comply with the regulations so I don't think there should be any problems.
Looking forward to the trip in 2 weeks today but again, I'm only going as far as Kalgoorlie.
thanks again....Andrew
#10 Posted : Sunday, 17 July 2011 7:00:25 AM(UTC)
A tip which I find useful is to arrange the driving lights so the beams cross over around 100metres ahead, this allows the beams to go around bends so you can get some idea what is ahead. a bit of practice will tell you just where to set the crossover.
bluHJ Offline
#11 Posted : Monday, 18 July 2011 1:22:33 AM(UTC)
bluHJ
I never thought of that. Might give it a try.
Guest (6)
