#1 Posted : Tuesday, 19 July 2011 6:05:36 AM(UTC)
having cleverly reversed the vr into the corner of the trailer I now need a right hand tail light. believe ute/wagon vn-vs are the same.
can get them easy I know, just thought i would some members a chance to clear some stuff out.
north of perth suburb please.
Edited by user Tuesday, 19 July 2011 9:33:09 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 19 July 2011 9:05:59 AM(UTC)
Yes, they are the same - but there are 2 types - clear & smoked, so check what you have.
Berlina wagons got the 'smoked' lenses - the red is a lot darker than the non-smoked ones, and the reverse light lense looks a bit grey/brown around the edges.
You won't notice it much until you compare it to another light, or put 1 of each on the same car - then it's obvious.
You can sort of see the difference if you scroll down this page:
http://shop.holmart.com.au/category33_2.htm
#3 Posted : Tuesday, 19 July 2011 9:32:10 AM(UTC)
thanks Mick, pretty obviously clear reverse its like glass.
