#1 Posted : Friday, 28 May 2004 5:28:11 AM(UTC)
You can get a nice vr commodore or even vs for that sort of money.
The vn/vp are pretty shit. vn series 1 is worse,The first efi buick v6 engine. There are too many problems to name. Series 2 vn has the better motor which is used on vp as well, but still has a really rogh idle. The body is really shit and feels really light. The vr/vs is the one to get. Vs is a lot better this has the refined smooth idiling buick v6 called ecotec v6. anything over 150,000 km probably check wheel bearings, (are non adjustable have to replace whole hub assembly, pretty easy to fit),shocks, water pump, steering rack (usually stuffed). Check that all electronics work as well sometimes bcm stuffs up.
cheers get a vs
