can you braniacs please have a look at this and help with some numbers? http://oldholden.com/?q=node/27879#comment-111515
Your VIN and Body ID Plate match as a 350 in a Kingswood V8. As stated in AMC early 350s used this 04 Luxury code while later ones used 18 for GTS 350. See Issue 21 Sept/Oct 05. The QR at the end of the model no is HQ series, Right hand drive. Ja Edited by user Saturday, 15 April 2006 6:05:48 AM(UTC)
| Reason: Not specified |
You only have to be in front at the end of the race. |
Hi Guys.
Yes, JBM has answered most of it.
It appears, from the numbers given, to be a '74 HQ Monaro GTS 350 4-door with a TH400 transmission.
The 5th digit in the VIN is U = 350ci V8. The 6th digit is D = 1974 (actually 9/83 onwards). On the bod |
thanks guys, i've only recently got a copy of the monaro facts so i'm still a bit green when it comes to deciphering it all...and there's a lot...
If you go to the body id plate section in the Monaro story/fact there it shows what all the information on this tag means, includiung the QR from Sydney plant and the WXYZ on the trim line.
Warren
