#1 Posted : Saturday, 15 April 2006 8:38:31 AM(UTC)
I need a couple of parts for a twin turbo kit off a Supra. (just bought the turbos, not the Supra).
I need the clamp thingy that holds the turbo to the manifold, its about 75 mm across and splits in two, I need the female side, that is the side that does not have studs just holes for the studs on the other side to go through, but would buy a complete clamp if necessary.
Also I need the activating canister thing I think it is vacuum operated, along with the lever. I need two of these if possible but again would look at anything.
Thr turbo model is Toyota CT12 or CT12A, otherwise known as 1G-GTE, or 1J .
This page was generated in 0.015 seconds.
