phill Offline
#1 Posted : Friday, 25 November 2011 2:06:28 AM(UTC)
phill
Hey guys I have seen a few products that acts as a Lead Substitute for older and LPG vehicles, I would like to know the best or most common product and also would like to know it there is some good to bad products to purchase or to try an avoid?
I have a XB 302, and I NEVER use E10, I just put unleaded in it most times, what do you guys recon makes a good mix?
Cheers Phill.
gcg2503 Offline
#2 Posted : Friday, 25 November 2011 4:22:17 AM(UTC)
gcg2503
Hi Phill
I always use 98 Octane fuel and throw in some Nulon valve lube shown below
http://www.getprice.com....e-Gpnc_641--37209482.htm
George
phill Offline
#3 Posted : Friday, 25 November 2011 7:27:32 AM(UTC)
phill
Great! that's one product that I have used, I will keep to that and its good to know it's safe, Cheers.
xwgs70 Offline
#4 Posted : Friday, 25 November 2011 9:33:44 AM(UTC)
xwgs70
Hey phill I use a product called flashlube ,used it for my 351 before I put alloy heads on .still use it in my 250 6cyl .they make a bottle that goes under the bonnet that is vacuum feed into your adaptor below your carburettor ,have used it for 5 years no troubles,used it since motor was rebuilt .WWW.flashlube.com.au Australian made .
phill Offline
#5 Posted : Tuesday, 29 November 2011 3:17:03 AM(UTC)
phill
Hi xwgs70, yeh I have also used Flash Lube too and it seems to be ok, but has anyone heard of bitron? (I think I spelt it right) I got told that it is the best, does anyone know if this or is it a whole lot of hot air?
PS, I will check out that site too,
Cheers.
