rexy Offline
#1 Posted : Monday, 9 January 2012 9:43:42 AM(UTC)
rexy
Stumbled across what appears to be a bit of an oddity in the shed the other day.
Cleveland block with cast code of D2AE-CA and cast date of 2A11 which as far as I can tell should be a cobra jet 4 bolt block cast on 11th january 1972. It appears to be a 2 bolt block though.
Any thoughts?
castellan Offline
#2 Posted : Monday, 23 January 2012 7:02:41 PM(UTC)
castellan
It's no different to any other Cleveland block.
The D2AE-CA blocks were in other cars as well in 2 bolt.
CA is only the revision.
rexy Offline
#3 Posted : Monday, 30 January 2012 5:56:13 AM(UTC)
rexy
Any other opinions before it gets sent for scrap?
If its not anything special then there are better condition blocks around and this one will go to the scrappy.
#4 Posted : Monday, 30 January 2012 7:15:53 AM(UTC)
Stick it on ebay for $10 you will probably save it from a trip to China and get more than a scrappy will give you.
302Superbird Offline
#5 Posted : Tuesday, 31 January 2012 8:21:52 AM(UTC)
302Superbird
What is the bore at? Might be worth more than $10?
