All.. Over a 20km drive my EF is losing all water in the radiator. I'm not sure what else to look for except that it could possibly be a faulty radiator cap, thermostat. The head is fine.Haven't had a chance to have a good look yet but Any thoughts would be great.
Welsh plugs are common to leak.
Get a pressure test done dude. That should show where the leak is coming from.
You have been a member since:: 1/03/2005(UTC) Posts: 1,991
Most likely the cap is buggered and each time you stop the engine it allows a small amount of water to escape. Try a new cap. It's about the cheapest fix there is! Worth trying first.
Cheers guys. Had a good look at it the other day. Looks like the head gasket has given out near the intake manifold. Not happy.
