I have 202 on LPG with VH electronic ign distributor and coil. Max rpm I would do is 5500 rpm
I believe NGK plugs 1 range hotter are a good plug for this setup
My question is what leads should I use. I have Top Gun silicon and they have lasted 10,000km and are breaking down even at idle. Are there other options that will provide higher voltage with less resistance.
Cost is not the issue here, I want the best for this application |
Actually I did yet another search and "spiral wound" leads come up. Any ideas ?
I don't usually ask questions, but this one is out of my understanding. Thanks |
The best leads u can use r spiral ignition leads u will never have a problem again. I fit these leads to all the cars in my mechanical workshop and r yet to have a problem. We have these leads custom made and they r the best around. They use these leads o
Sounds great, I run LPG too, where do we get these leads from?
Peter (not Peter S!).
Never late with a 308!! |
202 and three on the tree, can't get more Aussie than that!! |
Hi Guys.
The best ignition leads are 'Magnecor' spiral type leads. Use 7mm for standard ignition & 8mm for HEI.
If in Sydney ring Thundercords on (02) 9897-3777 or in Melbourne see Dick O'Keefe at Performance Ignition (03) 9872-3644.
Dr Terry. |
These leads are located in victoria ph 0408593241 Ross
Thanks Terry, I have already phoned Dick and he has also confirmed spiral leads. I am very confident this is the way to go. Dick also has an EH - an S4. |
Hi Peter.
Yes, Dick's car is probably the best S4 in Australia.
Dr Terry. |
Top bloke, he can talk for ages about his car. Really nice and knows ignition like no-one else. |
