#1 Posted : Wednesday, 3 May 2006 2:15:08 AM(UTC)
i'm guessing that smartlock is the problem here. Sometimes when I go to start the engine the motor will crank once and then stop, if you hold the key to the start position it will crank again after 2 or 3 seconds. I first thought this could be starter motor solenoid but its been replaced recently, any ideas??????????????????
