toby Offline
#1 Posted : Wednesday, 2 May 2012 5:37:38 AM(UTC)
toby
hi.
has anyone got a t,bar shifter for sale, to suit the 308 tri matic box for the 73 hq coupe?
any coupe parts will be of interest...cheers
HQ.GTS.COUPE.
gmholdman Offline
#2 Posted : Thursday, 3 May 2012 4:07:24 AM(UTC)
gmholdman
I have seen Gemini auto shifters fitted ? al.
toby Offline
#3 Posted : Thursday, 3 May 2012 4:23:48 AM(UTC)
toby
hi mate...thats interesting ..do you know someone who has done this ? cheers...toby.
HQ.GTS.COUPE.
#4 Posted : Thursday, 3 May 2012 6:05:42 AM(UTC)
Any HQ-HZ or LH-LX rod style T-bar shifter will do you as long as it isn't from a TH400 car UNLESS you have a left hand shift trimatic (Commodore style) then you want a TH400 rod type shifter.
toby Offline
#5 Posted : Thursday, 3 May 2012 7:36:25 PM(UTC)
toby
ok, thanx mate. the box is coded L.M. , with a left side shift.must b out of a commodore??
HQ.GTS.COUPE.
#6 Posted : Thursday, 3 May 2012 9:06:18 PM(UTC)
An LM code Tri-Matic was fitted to early VH 5.0 & WB 5.0 floor shift.
#7 Posted : Thursday, 3 May 2012 10:16:38 PM(UTC)
Yes, so you want a HQ-HZ TH400 rod type shifter. You can knock the roll pins out of a HQ-WB RH shift trimatic one and swap it around too. Just see what you can find.
This is a complete TH400 one, what you really want. You also want the harness that goes from the shifter to the dash. http://www.ebay.com.au/i...ries&hash=item3a73a6a1e8
Here is a RH shift Trimatic one: http://www.ebay.com.au/i...ries&hash=item3a73c82cc5
Best bet is to pull one out of a car yourself, grab attaching screws, threaded clip nuts out of the tunnel, harness etc (the whole lot). Don't be worried about a broken T-bar bit as these are available repro.
toby Offline
#8 Posted : Saturday, 5 May 2012 2:11:46 AM(UTC)
toby
thanx heaps fellas. its really apreciated.when i learn to upload photos, i will send a few as we go through the resto.
...........thanx again...toby.
HQ.GTS.COUPE.
