hi. has anyone got a t,bar shifter for sale, to suit the 308 tri matic box for the 73 hq coupe? any coupe parts will be of interest...cheers |
HQ.GTS.COUPE. |
Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 7 time(s) in 7 post(s)
I have seen Gemini auto shifters fitted ? al.
hi mate...thats interesting ..do you know someone who has done this ? cheers...toby. |
HQ.GTS.COUPE. |
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
Any HQ-HZ or LH-LX rod style T-bar shifter will do you as long as it isn't from a TH400 car UNLESS you have a left hand shift trimatic (Commodore style) then you want a TH400 rod type shifter. |
ok, thanx mate. the box is coded L.M. , with a left side shift.must b out of a commodore?? |
HQ.GTS.COUPE. |
An LM code Tri-Matic was fitted to early VH 5.0 & WB 5.0 floor shift. Dr Terry |
Yes, so you want a HQ-HZ TH400 rod type shifter. You can knock the roll pins out of a HQ-WB RH shift trimatic one and swap it around too. Just see what you can find. This is a complete TH400 one, what you really want. You also want the harness that goes from the shifter to the dash. http://www.ebay.com.au/i...ries&hash=item3a73a6a1e8Here is a RH shift Trimatic one: http://www.ebay.com.au/i...ries&hash=item3a73c82cc5Best bet is to pull one out of a car yourself, grab attaching screws, threaded clip nuts out of the tunnel, harness etc (the whole lot). Don't be worried about a broken T-bar bit as these are available repro. |
thanx heaps fellas. its really apreciated.when i learn to upload photos, i will send a few as we go through the resto. ...........thanx again...toby. |
HQ.GTS.COUPE. |
