6pak Offline
#1 Posted : Tuesday, 5 June 2012 6:03:51 AM(UTC)
6pak
Hi Folks
This query relates to our old Mazda 626 (lets just call it a Telstar for the purpose of this forum) :).
My wife drove it through a really deep puddle following some unusually heavyt rain. The water appears to have gone over the top of the bellhousing as i have removed leaves and sticks from the top of the housing. Now when I let the clutch out it doesn't engage smoothly but has a bit of a jerky feel as i let the clutch pedal out. Could the water have got in and caused the clutch plate to warp?
#2 Posted : Tuesday, 5 June 2012 7:06:27 AM(UTC)
I would say that you are correct about water getting in but rather than warp things it's probably covered the flywheel and/or pressure plate face with dirt or rust.
Hopefully it will clear up with a little bit of time or use.
