Going to look at a HJ Holden tomorrow thats been sitting under a tree for 10 years, and only has 140.000 KLM on it.
Any tip's where to look for rust in this model?
Roof along gutters, inside under headlining bottom corners of boot lid back edge bottom corners of all four doors on the outside bottom inner corners and top inner corners of the front doors all around the front and rear windscreens bottom front corners of the rear lower quarter panels top of the dogleg panels bottom of the dogleg panels sill panels bottom of the front guards front corners of the bonnet floors
Anywhere that shows any sign of surface rust on the outside has about fifty times more rust on the inside. |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Look up under the dash at the bottom of the plenumn. They can rust out from underneath and not be visible from outside under the windscreen.
everywhere there rust buckets |
why drink & drive when you can drift & slide |
Have a look at Rare Spares rust panels. That will give you an idea of the main areas that rust. Of course there a lot of other places that rust as well. Good luck with the job.
i have heaps o rust replacement cuts from original cars iv cut out over th years if you need anything?? original sections that will fit, & line up correctly, including any inner sections, that you may require, that no one reproduces wrecking HK,HT,HG,HQ/JXZ regards DD 0412109239 www.bellarineclassicautos.com.au
