keithholden Offline
#1 Posted : Monday, 20 August 2012 2:43:54 AM(UTC)
keithholden
Hi what would be the best way to remove the badges off front guard and boot lid without putting a screwdriver under the badge. My neighbor asked me to ask you guys.
#2 Posted : Monday, 20 August 2012 4:51:04 AM(UTC)
Use an angle grinder, that way you won't damage the screw driver.
Edited by user Monday, 20 August 2012 5:55:19 AM(UTC)  | Reason: Not specified
#3 Posted : Monday, 20 August 2012 4:58:00 AM(UTC)
depends off what & how its attached, eg double sided tape or locator pins, you can use a thin bladed butter knife for both, but applying a little heat useing a hair dryer helps with the glued/taped type.
69 rust bucket Offline
#4 Posted : Tuesday, 21 August 2012 1:48:31 AM(UTC)
69 rust bucket
try a paint scraper its got more surface area to keep damage to a minimum
why drink & drive when you can drift & slide
keithholden Offline
#5 Posted : Tuesday, 21 August 2012 1:59:53 AM(UTC)
keithholden
K ill let him know to try a scraper inside the panel and see how he goes cheers
stephenreed Offline
#6 Posted : Wednesday, 22 August 2012 1:52:30 AM(UTC)
stephenreed
I've used a paint scraper blade to remove the badges of my WH statesman. You just have to take it slow and be very careful as a blade is unforgiving on the duco.
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
