Fastlane
Holden Forums
Holden General Discussion
Wheel stud thread - are hq the same as lj torana
gday
was wanting to know if hq-hz holdens have the same wheel stud thread as the lc-lj toranas? so are the wheel nuts interchangable between them?
cheers BigMo
i know the lj thread hq hz
sorry i know the lj thread is 7/16 unf. not sure what hq through to hz are though. hope this helps
all holdens upto WB including torana's use 7/16" studs. Edited by user Sunday, 28 May 2006 2:58:14 AM(UTC)
| Reason: Not specified
HT onwards use the same wheel nuts. HK and earlier have the same thread but different taper. Not sure if the very early LC's used HK nuts or not. |
thanks guys that's all very helpfull
Fastlane
Holden Forums
