#1 Posted : Sunday, 9 December 2012 8:32:32 AM(UTC)
Looking for a late HQ air cleaner that has the snorkle pointing off the the passengers side with the exhaust pre-heat valve thingy on it. The engine breather should come off the front of the right side rocker cover and connect to the front right of the air cleaner . . . thats the hard option to find. Most of the breathers connect to the rear of the left rocker cover. So there it is, a late HQ to HJ 4-barrell air cleaner, WHOS GOT ONE?
#2 Posted : Sunday, 9 December 2012 6:23:37 PM(UTC)
Was thanked: 632 time(s) in 594 post(s)
I have at least one, off a HJ that i'm using on my Premier. Not sure what else is up there. Will have a look next time i'm in that corner of the mezzanine! The one with the left rear PCV breather is the LH-LX ADR27 Torana one. Late HQ and HJ Holdens and Statesmans come off the front right, most of them do anyway.
#3 Posted : Sunday, 9 December 2012 8:47:09 PM(UTC)
Yeah late HQ, HJ, LH & early LX 308 (ADR27) air cleaner. Thet also had an extra hose stub fitting for the fresh air supply hose to the automatic choke heat tube. Breather definately goes to the front of the right side rocker cover and the PCV is located on the rear of the left rocker cover.
Theres a couple of photos of one on the bottom of this page:
http://www.fastlane.com....topic.asp?TOPIC_ID=22931
I'd be interested if you have one, thanks.
#4 Posted : Monday, 10 December 2012 1:22:14 AM(UTC)
Only HQ and HJ. Torana has the PCV breather on the rear of the LH rocker cover.
#5 Posted : Monday, 10 December 2012 3:19:33 AM(UTC)
"Torana has the PCV breather on the rear of the LH rocker cover"
Thats what I said, PCV at rear of left rocker cover. Late HQ and HJ's had that didnt they?
Edited by user Monday, 10 December 2012 3:23:43 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 10 December 2012 7:00:14 AM(UTC)
Holden and Statesman are opposite to Torana. Torana has the PCV valve where HQ/J have the PCV breather.
wannabe51 Offline
#7 Posted : Tuesday, 11 December 2012 2:49:55 AM(UTC)
wannabe51
Hi there,
I have an air cleaner with all the bits and pieces.
It came of a 308 with 4 barrel Rochester.
Has all the decals (GMH 5 Litre)
Is this what you are chasing?
cheers Dave
#8 Posted : Tuesday, 11 December 2012 5:49:21 AM(UTC)
Originally posted by wannabe51
Hi there,
cheers Dave
Hi Dave, theres about four different 308 air cleaner assemblies. If it has the breather in the exact same position as the one in this photo I'd be interested in buying it from you mate.
Email a photo or two if you can, . . . v8monaro(at)tpg.com.au
Wayne
wannabe51 Offline
#9 Posted : Wednesday, 12 December 2012 10:53:11 PM(UTC)
wannabe51
Hi Wayne,
I will send you a photo of the air cleaner I have as soon as I can.
Cheers, Dave
#10 Posted : Thursday, 13 December 2012 8:43:42 AM(UTC)
Hi Wayne,
Cheers, Dave
Thanks Dave
#11 Posted : Friday, 21 December 2012 9:15:28 AM(UTC)
* Still looking for a late HQ - HJ air cleaner assembly as shown in the photos above.
* Also looking for a good original HQ fan cowling/cover plate. Not a new repro.
* Original 308 253 thermostat housing in decent condition would be nice too.
#12 Posted : Monday, 28 January 2013 6:19:46 PM(UTC)
Still looking for a late HQ-HJ air cleaner assembly
antoni Offline
#13 Posted : Tuesday, 29 January 2013 12:20:08 AM(UTC)
antoni
Hi are you still looking for a original HQ fan cowling/cover plate.
Thanks Tony...
#14 Posted : Tuesday, 29 January 2013 6:46:03 PM(UTC)
Thanks Tony...
I've got one Tony thanks anyway.
Guest (9)
This page was generated in 0.136 seconds.
