Goodo Offline
#1 Posted : Tuesday, 8 January 2013 2:39:36 AM(UTC)
Goodo
Hi, what would be the best size carby for my 289 in a xp falcon, new motor and mild cam, not used for racing just cruising. the one I took off before rebuild was 2 barell motorcraft.
Dean
#2 Posted : Tuesday, 8 January 2013 2:50:11 AM(UTC)
Apparently a 350 Holley is perfect for a 302 so it should not be too bad on a 289.
However the dyno tune shop that told me that and tuned the 350 Holley to my 179 did a brilliant job of making the car really drivable but I lost a lot of top end grunt with the 350 that I had before with the previous 600 Holley because the engine was worked and balanced to rev easily to 7000rpm.
Mild cam you might get away with a 500 Holley or a step up to a 4 barrel manifold and a 600 Vac Sec Holley or even a Quadrajet from a 308 as they are a brilliant carby IMHO.
Paul351xb Offline
#3 Posted : Tuesday, 8 January 2013 9:51:14 AM(UTC)
Paul351xb
quadrajet is a very underated carb.
www.earlyfalcons.com Offline
#4 Posted : Wednesday, 30 January 2013 7:40:41 AM(UTC)
I have a fairly stock 302 in my XM coupe with 350 Holley, anything over that is excessive if you are just wanting to cruise and have decent fuel economy.
Deon
