Hi, I'm after a complete 253 engine, and possibly a 4 speed for a conversion into my wb van to replace the 202, preferably complete runner in brizzy area, sunny coast, or goldy... Cheers
Got a Blue motor 278, L34 Heads and cam, Built by Bob Campbell, Group A inlet manifold, 4 barrel Rochester with a T500 gearbox. Great combo and motor in quick and very strong. Only prob i'm in W.A. go on youtube to hear motor running, enter Bob Campbell engines.
Make sure you get a WB V8 clutch pedal too. Only need the pedal if it is already a manual, rest is already there. 6cyl pedal is different. If you already have an aussie 4spd M20, just change the input shaft and cover. Whatever box you buy nowadays should be pulled apart to check and replace worn bits. |
You are a member of these groups:: Registered
have a complete blue 253 and auto box. was running when came out of car if ya interested. in rockhampton.
