hk350 Offline
#1 Posted : Thursday, 28 March 2013 11:30:42 PM(UTC)
hk350
G'day fellas, desperately chasing a HK subframe, will buy or have a good HG frame to swap with. Car is nearly done in the beaters so need 1 ASAP. Am in WA but will buy from interstate. Reply with what you have. Cheers, Glenn.
ht307munro Offline
#2 Posted : Friday, 29 March 2013 6:34:09 AM(UTC)
ht307munro
Mate unless you want your car to be as close to factory as possible if you have a good HG one just remove the gearbox crossmember extension mounts. Will save you a heap of money if freighting from eastern states.
Alex
The HKTG Garage Offline
#3 Posted : Friday, 29 March 2013 9:01:33 AM(UTC)
The HKTG Garage
True, but then he has to chase the grille mounting brackets that HT HG didnt have and spot weld them on.
hk350 Offline
#4 Posted : Friday, 29 March 2013 12:08:43 PM(UTC)
hk350
Yeah mate, aware of that. Spending a few bucks on the resto so my as well do it properly.
mph61 Offline
#5 Posted : Saturday, 30 March 2013 5:42:50 AM(UTC)
mph61
You may have seen it but a HK single light subframe on Ebay $100 Buy it now $400
