HK MONARO Offline
#1 Posted : Thursday, 18 July 2013 4:10:48 AM(UTC)
HK MONARO
Hi Guys, I am restoring my 4 speed Saginaw gearbox, my original gears, input shaft and cluster are pretty badly pitted and need to be replaced.
I am looking for new if not great second hand.
Cluster / Tooth count 25, 21, 19, 15, 15
Input shaft 1 groove + 19 teeth
1st gear 29 teeth outside diameter 4.165
2nd gear 26 teeth outside diameter 3.695
3rd gear 23 teeth outside diameter 3.395
3rd and 4th hub and sleeve assembly
Thanks, Look forward to your reply
Premier 350 Offline
#2 Posted : Thursday, 18 July 2013 6:23:00 AM(UTC)
Premier 350
Can't help with parts, but have you tried any US based suppliers?
HK MONARO Offline
#3 Posted : Thursday, 18 July 2013 7:19:05 AM(UTC)
HK MONARO
thanks only just tried as well but was hoping someone here has something their not using
