Reno Offline
#1 Posted : Tuesday, 23 July 2013 7:24:53 AM(UTC)
Reno
What is the heater hose setup on a Alloy Head XF Falcon ?? Currently is it from waterpump to "T" junction then branches to the rear manifold inlet port and the other branch to the heater port closest to the motor - then from the top port of the cyl head to the vacuum control valve then to the heater. Since the flow is from the waterpump I would have thought that the vacuum control valve should have been between the "T" junction and the heater, otherwise in the summer there would be heated water flowing through the heater up to the vacuum control valve. Please advise the what the setup is on your XF. Thanking you for checking.
Paul351xb Offline
#2 Posted : Tuesday, 23 July 2013 9:54:30 AM(UTC)
Paul351xb
Wish I had an xf to check. Should be the same set up as the XD and XE.
Reno Offline
#3 Posted : Thursday, 25 July 2013 6:49:22 AM(UTC)
Reno
Appreciating you trying to be helpful
This page was generated in 0.949 seconds.
