Jade Offline
#1 Posted : Monday, 5 August 2013 2:08:09 PM(UTC)
Jade
Hi we have a 1975 HJ kingswood ute V8 floor shift with GTS (sports dash). It has single headlights and is in good nick except for a paint job. What would this be worth?
#2 Posted : Monday, 5 August 2013 5:18:04 PM(UTC)
JAde
Post up some ID plate details. Does it have buckets? Is it very late 1975 or prior to 10/75.
It may be a Sandman is the reason for the questions.
Jade Offline
#3 Posted : Monday, 5 August 2013 5:47:17 PM(UTC)
Jade
HJ75-A 5045.0 engine capacity variant HJ-75I
BHJ05602M
Axle code R11
Engine number 110T13113 this is second engine
Bucket seats
Gvm 2310
Built 5/75
What would it be worth?
Jade Offline
#4 Posted : Monday, 5 August 2013 5:48:35 PM(UTC)
Jade
10 bolt diff
Has crome around taillights
GTS dash
4 shift on floor
#5 Posted : Tuesday, 6 August 2013 3:19:08 AM(UTC)
You need the details off the ID plates. You've got the chassis number. Just check the same ID plate for seating capacity and GVW (will be 2155kg or 2200kg). The number off the skinny plate, and the data off the big plate on the passenger side.
Jade Offline
#6 Posted : Tuesday, 6 August 2013 3:55:30 AM(UTC)
Jade
Looks like the plates have been removed on the passengers side
The drivers door has been replaced as well
And the gvm is 2200
Jade Offline
#7 Posted : Tuesday, 6 August 2013 3:56:43 AM(UTC)
Jade
The skinny plate number is 8N80TEJ478307J
Guest (6)
