lucas2655 Offline
#1 Posted : Saturday, 7 September 2013 9:10:29 PM(UTC)
lucas2655
Does anyone know if later model seats will fit straight into a VH? If not, does anyone know of any aftermarket ones that come with the correct rail kit? Any help would be greatly appreciated!!!!
Many thanks,
Lucas2655
#2 Posted : Saturday, 7 September 2013 11:56:10 PM(UTC)
With a little bit of mixing & matching of factory rail components, any VN-VS front seats will fit, and this is a swap that can be done at home with only a few tools. You need the rails from a pair of later VL seats (post october 87), as well as the passenger VN-VS seat.
Later than VS it becomes a lot more hassle as the runners are so different.
lucas2655 Offline
#3 Posted : Sunday, 8 September 2013 1:35:03 AM(UTC)
lucas2655
Thanks Mick. Ill start the search for a set of rails. Ill keep this updated as i go.
Many thanks,
Lucas2655
Balfizar Offline
#4 Posted : Thursday, 12 September 2013 4:51:34 AM(UTC)
Balfizar
Was thanked: 16 time(s) in 16 post(s)
Don't forget to weld up the cracks in the floor pan around the seat mounting bolts diagonals left front and right rear. Also weld in the seat/floor pan bracing channels if you have not got them while you are at it.
Balfizar
