#1 Posted : Thursday, 5 December 2013 12:03:16 PM(UTC)
Will a Caprice front bumper bolt straight on to a VR?
#2 Posted : Thursday, 5 December 2013 6:56:36 PM(UTC)
As long as you have the reinforcement with the bar then yes, but it creates a bucketload of problems:
1. The grill is mounted on the bonnet on a caprice, it's part of the bumper on a regular VR
2. The opening for the side blinker lenses on a VR are much shorter than a Caprice, so the bumper plastic won't fit the opening, and has to be cut away.
3. The wiring for the blinkers & park lamps is different.
You really need to swap the bar, reo, bonnet, grille & front guards over as a complete set.
The only common part is the headlights & blinkers - just the bodies of them - the wiring harnesses to the lamps are different too!
#3 Posted : Friday, 6 December 2013 12:03:25 PM(UTC)
Wow thanks knew it was too good to be true.
any one in WA got a dark blue left guard and bumper for VR/VS?
adam PERTH Offline
#4 Posted : Sunday, 15 December 2013 10:49:53 AM(UTC)
adam PERTH
VR VS guards are different for VR VS statesman and Lexen
