coxy Offline
#1 Posted : Thursday, 12 December 2013 7:53:47 AM(UTC)
coxy
Hi all i want to change studd pattern in my hg van so i have a wider range of wheels to choose from. I have a 3.08 fine spline diff and housing out of a hx holden. I can get housing modified to bolt up to my leaf springs but the front is my worry. Can i just change the stubb axles . Is it that easy. Anyone know? cheers
JBM Offline
#2 Posted : Thursday, 12 December 2013 8:29:55 AM(UTC)
JBM
You can get front rotors from DBA with the stud pattern of your choice.
James
Premier 350 Offline
#3 Posted : Thursday, 12 December 2013 8:43:06 AM(UTC)
Premier 350
#4 Posted : Thursday, 12 December 2013 4:18:23 PM(UTC)
HG stubs are the same basic thing as HQ-WB stubs.
coxy Offline
#5 Posted : Friday, 13 December 2013 9:35:48 AM(UTC)
coxy
righto so if i get hq-wb disc and rotors and calipers it will all bolt up and be good?
