Hoping someone can help. Disconnected battery today to clean up carrier, probably out for 2 hours. When re-connected, instruments went crazy (fuel gauge, warning lights), air conditioning / climate control doesn't work and power steering is heavy.
Any insights would be greatly appreciated.
Petered.
Try disconnecting the battery again, wait a few minutes & the re-connect again.
If that doesn't fix the problem, try unplugging the ABS module & see what difference that makes. If everything returns to normal (excepting the ABS & Trac light being lit) you have a faulty ABS module.
Dr Terry |
Many thanks for your counsel. Will try what you suggest. Sincerely, Peterd
