Hoping someone can help with advice. Recently cleaned under wheel arches (lots of crud) and subsequently had a body module issue. Through isolating the ABS have concluded that it is an ABS issue. It is suggested that a sensor may be "clagged up" from the cleaning process and that removing the crud may rectify the problem. Does anyone have any thoughts? If I am on the right track, what is the best way to clean the sensors?
Any counsel will be greatly appreciated. Petered
I doubt that you have any problem with the sensors. The ABS module is the more likely fault.
What are the symptoms.
I can supply you a module at trade rates if you need. Where are you located.
Dr Terry |
